1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Epics Archiver not pushing to STS?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 1 Dec 2020 21:11:22 +0000
This was the result of the storage status
jetson@ubuntu:/opt/epicsarchiverap$ bash /opt/epicsarchiverap/archappl.bash status
>>> Current Time 2012011310
>>> Archiver Appliance Status    http://ubuntu:17665/mgmt/ui/index.html
                        OR
    http://192.168.252.131:17665/mgmt/ui/index.html
                         OR
    http://localhost:17665/mgmt/ui/index.html
>>> Consult Service Logs
  tail -f /opt/epicsarchiverap/mgmt/logs/archappl_service.log
  tail -f /opt/epicsarchiverap/engine/logs/archappl_service.log
  tail -f /opt/epicsarchiverap/etl/logs/archappl_service.log
  tail -f /opt/epicsarchiverap/retrieval/logs/archappl_service.log
>>> Service PIDs
    All Tomcat processes
    Archiver Appliance PIDs
cat: /opt/epicsarchiverap/mgmt/temp/mgmt.pid: No such file or directory
        mgmt : pid      0 exists.
cat: /opt/epicsarchiverap/engine/temp/engine.pid: No such file or directory
      engine : pid      0 exists.
cat: /opt/epicsarchiverap/etl/temp/etl.pid: No such file or directory
         etl : pid      0 exists.
cat: /opt/epicsarchiverap/retrieval/temp/retrieval.pid: No such file or directory
   retrieval : pid      0 exists.
Sent: Monday, November 30, 2020 8:28 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Subject: Re: Epics Archiver not pushing to STS?
You may check the storage status via
bash /opt/epicsarchiverap/archappl.bash storage
Sorry for the typo in the argument.
Best,
Han
On Mon, Nov 30, 2020 at 8:15 PM Jeong Han Lee <[email protected]> wrote:
Please check the entire discussion at  https://epics.anl.gov/tech-talk/2020/msg01959.php
HTH,
Han
On Mon, Nov 30, 2020 at 5:39 PM Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Hello All,
I have been successful in getting the epics archiver appliance to archive PVs that are running in soft IOCs locally on the same machine as the archiver.  But now I tried to archive an IOC that is running on a subnet 192.168.40.x and it is says its connected/archiving but it never pushes to STS. It does show the details from the record for caLab:dmm shown below, which seems like its able to read from it. Settings for archiver appliance.xml below and also the archappl.conf environment variables set for the subnet to be seen.  I am able to also use caget through cmdline to get values from caLab:dmm and CSStudio is able to monitor them but the archiver doesn’t seem to be actually saving the data.
<appliances>
   <appliance>
     <identity>appliance0</identity>
     <cluster_inetport>localhost:16670</cluster_inetport>
     <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://localhost:17666/engine/bpl</engine_url>
     <etl_url>http://localhost:17667/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
   </appliance>
</appliances>
JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
CATALINA_HOME="/usr/share/tomcat9"
CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
ARCHAPPL_MYIDENTITY="appliance0"
ARCHAPPL_STORAGE_TOP="/arch"
ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
EPICS_CA_ADDR_LIST=192.168.40.200
EPICS_CA_AUTO_ADDR_LIST=YES
caLab:dmm PV details section showing Never for STS push
Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Re: Epics Archiver not pushing to STS? Jeong Han Lee via Tech-talk
Prev: RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Next: RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
