1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: aSub debug output
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Daykin, Evan" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 2 Dec 2020 12:39:26 -0800
On 12/2/20 11:42 AM, Daykin, Evan via Tech-talk wrote:
> Hi again and thank you all for your suggestions.
> I spent some time creating a minimal example, and it behaves, of course, as you all said it does – a simple printf works. The problem is that one of my input links was not resolved, so it did not call the subroutine. I didn’t think of this possibility since TPRO showed the record processing, but Martin pointed me to the documentation where it says:
> ·         If all input-link fetches succeeded, call the routine specified by SNAM.
> Now my question becomes: is there a field that can be set such that this failure is not silent, e.g. raise LINK alarm or output some error message indicating which fetch failed?
Not a field, but you can (and imo. should) add the "MSI" modifier to all of your links.
Re: aSub debug output Johnson, Andrew N. via Tech-talk
aSub debug output Daykin, Evan via Tech-talk
RE: aSub debug output Daykin, Evan via Tech-talk
Prev: RE: aSub debug output Daykin, Evan via Tech-talk
Next: RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: aSub debug output Johnson, Andrew N. via Tech-talk
