1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Epics Archiver not pushing to STS?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 2 Dec 2020 20:45:05 +0000
Thank you for the help everyone, I will make sure to correct the timing issue.  As for knowing the delta at which it breaks was just curiosity no big deal.
  I did have one more question with regards to the archiver Han.  The archiver is now posting to STS but when I look at the waveform record data, it looks very incorrect.  I looked at my archived DMM resistance measurements and it looked fine.  I also have CS Studio showing the waveform data live and it looks great but the archived data did not seem like it was storing the data correctly?
Sent: Tuesday, December 1, 2020 5:13 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Subject: Re: Epics Archiver not pushing to STS?
I forgot to tell this. If you want to use that specific script directly outside the systemd service, you need "sudo" permission.
Your IOC and a host in an archiver appliance should have the same NTP server configuration. Technically, it doesn't matter which NTP server will be used. But better to use a single one instead of multiple ones.
I don't test the time offset. Maybe some number in the archiver appliance source?  Do you really need this?
Han
On Tue, Dec 1, 2020 at 4:09 PM Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Ah thanks Han I see the services running now with the status script when using sudo.  Also I seemed to have stumbled into the solution, the clock on the PXIe was set one hour ahead of my laptop.  Apparently the archiver will throw out data that is not close enough to its clock.  Does anyone know what the  margin is between timestamps before the archiver will not archive the data?
Thanks for all your help as always!
Sent: Monday, November 30, 2020 8:28 PM
You may check the storage status via
bash /opt/epicsarchiverap/archappl.bash storage
Sorry for the typo in the argument.
Best,
Han
On Mon, Nov 30, 2020 at 8:15 PM Jeong Han Lee <[email protected]> wrote:
Please check the entire discussion at  https://epics.anl.gov/tech-talk/2020/msg01959.php
HTH,
Han
On Mon, Nov 30, 2020 at 5:39 PM Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Hello All,
I have been successful in getting the epics archiver appliance to archive PVs that are running in soft IOCs locally on the same machine as the archiver.  But now I tried to archive an IOC that is running on a subnet 192.168.40.x and it is says its connected/archiving but it never pushes to STS. It does show the details from the record for caLab:dmm shown below, which seems like its able to read from it. Settings for archiver appliance.xml below and also the archappl.conf environment variables set for the subnet to be seen.  I am able to also use caget through cmdline to get values from caLab:dmm and CSStudio is able to monitor them but the archiver doesn’t seem to be actually saving the data.
<appliances>
   <appliance>
     <identity>appliance0</identity>
     <cluster_inetport>localhost:16670</cluster_inetport>
     <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://localhost:17666/engine/bpl</engine_url>
     <etl_url>http://localhost:17667/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
   </appliance>
</appliances>
JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
CATALINA_HOME="/usr/share/tomcat9"
CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
ARCHAPPL_MYIDENTITY="appliance0"
ARCHAPPL_STORAGE_TOP="/arch"
ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
EPICS_CA_ADDR_LIST=192.168.40.200
EPICS_CA_AUTO_ADDR_LIST=YES
caLab:dmm PV details section showing Never for STS push
Re: Epics Archiver not pushing to STS? Michael Davidsaver via Tech-talk
Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Re: Epics Archiver not pushing to STS? Jeong Han Lee via Tech-talk
RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Prev: Re: aSub debug output Michael Davidsaver via Tech-talk
Next: Re: Epics Archiver not pushing to STS? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Epics Archiver not pushing to STS? Ralph Lange via Tech-talk
