1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: EPICS support for Harvard Pump 33 DDS Syringe Pump
Date: Thu, 3 Dec 2020 04:59:00 +0000
Hi Mark,
Thank you for the suggestion. The commands are different between these two models, but yes, I can start with the IP module.
Best,
-Ji Li
发件人: Mark Rivers <[email protected]>
发送时间: 2020年12月2日 17:48
收件人: Li, Ji <[email protected]>
抄送: [email protected] <[email protected]>
主题: RE: EPICS support for Harvard Pump 33 DDS Syringe Pump
Hi Ji Li,
There is support in the ip module for the Harvard PHD2000 series syringe pumps (PHD2000.db, PHD2000.proto).  I don’t know if the command sets of the Harvard 33 DDS and PHD2000 series are compatible, but it is probably at least a good starting point.
From: Tech-talk <[email protected]> On Behalf Of Li, Ji via Tech-talk
Sent: Wednesday, December 2, 2020 4:25 PM
To: [email protected]
Subject: EPICS support for Harvard Pump 33 DDS Syringe Pump
Has anyone created EPICS support for Harvard Pump 33 DDS Syringe Pump?
-Ji Li
Beamline Controls
NSLS-II
Brookhaven National Laboratory
Upton, NY 11973
EPICS support for Harvard Pump 33 DDS Syringe Pump Li, Ji via Tech-talk
RE: EPICS support for Harvard Pump 33 DDS Syringe Pump Mark Rivers via Tech-talk
Prev: Re: aSub debug output Michael Davidsaver via Tech-talk
Next: RE: Ignore a welcome message in a telnet connection using StreamDevice Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: EPICS support for Harvard Pump 33 DDS Syringe Pump Mark Rivers via Tech-talk
Next: Using FPGA Transeiver Stefen Paul via Tech-talk
