1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Ignore a welcome message in a telnet connection using StreamDevice
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 3 Dec 2020 07:31:10 +0000
I added another record to the database and it seems the global init handler is called for each record. StreamDevice should work because the command interface is very simple, only this welcome message. I might try asynPortDriver meanwhile.
Best Regards,
Abdalla.
Sent: Tuesday, December 01, 2020 3:10 PM
To: Ralph Lange <[email protected]>; [email protected]
Yes, but for some reason the record ends up in an INVALID CALC_ALARM state. Could be that because @init should expect to read or write records?
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Tuesday, December 01, 2020 1:40 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Ignore a welcome message in a telnet connection using StreamDevice
On Tue, 1 Dec 2020 at 10:06, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
I am working on an IOC for a device that has its control interface through telnet. The problem is there is a welcome message that appears once every time I connect to the device using any telnet interface. The welcome message is in this form:
Hello world command shell
Type ‘?’ for help
And then I have to send “scpi>” in order to start the SCPI mode. Is it possible to ignore this one-time message and send “scpi>” just once in StreamDevice?
Have you tried a global @init handler?
The documentation [1] seems to suggest that this could work.
Cheers,
~Ralph
Ignore a welcome message in a telnet connection using StreamDevice Abdalla Ahmad via Tech-talk
Re: Ignore a welcome message in a telnet connection using StreamDevice Ralph Lange via Tech-talk
RE: Ignore a welcome message in a telnet connection using StreamDevice Abdalla Ahmad via Tech-talk
Prev: Re: EPICS support for Harvard Pump 33 DDS Syringe Pump Li, Ji via Tech-talk
Next: RE: Epics Archiver not pushing to STS? Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Ignore a welcome message in a telnet connection using StreamDevice Abdalla Ahmad via Tech-talk
Next: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
