>> As for knowing the delta at which it breaks
And, the requirement is to have monotonically increasing timestamps.
If you drop samples because of incorrect timestamps, you can see this in the PV Details; there is a separate line for this. There's is also a report that you can use to monitor all PV'S with dropped samples because of incorrect timestamps.
Hope that helps.
Murali
RE: Ignore a welcome message in a telnet connection using StreamDevice Abdalla Ahmad via Tech-talk
RE: aSub debug output Daykin, Evan via Tech-talk
<2020>
2025
2026
RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
