On Dec 9, 2020, at 3:14 PM, Manoussakis, Adamandios via Tech-talk < [email protected]> wrote:
I have been looking at older posts and have seen talk of increasing the scan rate from the default (I think) .1seconds but no definitive guide on how to? On a standard linux distro without RT_PREEMPT, is it possible
to push to say .01 or faster scan rates? Also I wanted to know does camonitor only update as fast as the scan rate limit, .1seconds currently?
There is no internal connection between CA monitor rates and the DB scan rates, it very much depends on your CPU, your IOC application and the clients you have connected as to how fast you would be able to run a periodic scan thread that sends out monitors.
Note that the IOC’s CA server can and does throw away monitor updates if the clients can’t keep up, so don’t design your systems assuming that your clients will always get every monitor if you’re running at high speeds.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
- RE: Faster Scan Rates possible? Manoussakis, Adamandios via Tech-talk
- Faster Scan Rates possible? Manoussakis, Adamandios via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
