Subject: RE: Faster Scan Rates possible?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 9 Dec 2020 21:33:29 +0000
Thanks Mark/Andrew for the insigh, is there any rule of thumb for how fast you can setup a SCAN rate in that dbd file for any current line of CPU (assuming more cores would help with threading and higher clock speeds).  Is it safe to say go to .01 .001 on current gen cpu hardware?
Sent: Wednesday, December 9, 2020 1:21 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Subject: Re: Faster Scan Rates possible?
On Dec 9, 2020, at 3:14 PM, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
I have been looking at older posts and have seen talk of increasing the scan rate from the default (I think) .1seconds but no definitive guide on how to?  On a standard linux distro without RT_PREEMPT, is it possible to push to say .01 or faster scan rates?  Also I wanted to know does camonitor only update as fast as the scan rate limit, .1seconds currently?
There is no internal connection between CA monitor rates and the DB scan rates, it very much depends on your CPU, your IOC application and the clients you have connected as to how fast you would be able to run a periodic scan thread that sends out monitors. Note that the IOC’s CA server can and does throw away monitor updates if the clients can’t keep up, so don’t design your systems assuming that your clients will always get every monitor if you’re running at high speeds.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: Faster Scan Rates possible? Manoussakis, Adamandios via Tech-talk
Re: Faster Scan Rates possible? Johnson, Andrew N. via Tech-talk
Prev: Re: Faster Scan Rates possible? Johnson, Andrew N. via Tech-talk
Next: RE: Faster Scan Rates possible? Manoussakis, Adamandios via Tech-talk
