1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Master DBD file for VisualDCT use
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 11 Dec 2020 00:33:13 +0000
On Dec 10, 2020, at 5:26 PM, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Does anyone have or know of a repo that has a dbd file with most or all of the record definitions to build DB files in VisualDCT?
Every site and potentially every IOC could use a different combination of record types, so I don’t think a community-wide file is likely to be terribly useful. If your IOCs are based on the synApps collection you could probably take the DBD file for the xxx IOC module and use that, but if not you’ll have to generate your own for your particular set of modules.
One complication is if/when new version of a support module containing a record type gets added that has new fields added which version do you use? That’s why I generally recommend using the DBD file for the specific IOC that you’re designing the database for.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Master DBD file for VisualDCT use Manoussakis, Adamandios via Tech-talk
Prev: Master DBD file for VisualDCT use Manoussakis, Adamandios via Tech-talk
Next: Phoebus Alarm Server Kafka consumer client John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
