1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Phoebus Alarm Server Kafka consumer client
From: John Dobbins via Tech-talk <[email protected]>
Date: Fri, 11 Dec 2020 02:27:49 +0000
All,
We are in the process of switching from the CSS Alarm Server which uses JMS to the Phoebus Alarm Server using Kafka.
For the old alarm server, I built a lightweight application which received server messages (via STOMP) and filtered them to pass along new alarms to SLACK. This is a stateless application, i.e. it doesn't try to maintain a list of PVs alarm states like the CSS Alarm Display but just passes along notification of new alarms (filters out acknowledgements and transitions to OK).  This has served us well - a notable exception being PVs which chatter in and out of alarm.  Interested parties can then check alarms details via CSS or web page. In the SLACK feed users may respond ("that was me doing x") or insert relevant data (plots, etc.)
I plan to do something similar for the new alarm server but wanted to inquire if anyone has already done something similar, has a Kafka consumer client which could be easily adapted, or has other ideas.  The major constraint is that I don't have a lot of time to work on this. 🙂
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Prev: Re: Master DBD file for VisualDCT use Johnson, Andrew N. via Tech-talk
Next: pvput to channelName of NTMultiChannel is having colon parsed Paduan Donadio, Marcio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
