1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: pvput to channelName of NTMultiChannel is having colon parsed
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
To: John Dobbins via Tech-talk <[email protected]>
Date: Fri, 11 Dec 2020 04:50:22 +0000
I’m trying to use pvput to insert EPICS PV names to the channelName array of a NTMultiChannel. I’ve created the NTMultiChannel with a minimum of fields, just for this first test. The error at the output says that “:” is not a known token as it is trying to parse the PV name instead of interpreting it as a generic string. I’m using EPICS base R7.0.3.1 both for the server and the clients.
$ pvput GMDTest:NTMultiChannel channelName="[abcdefg,hijklmn]"
Old : epics:nt/NTMultiChannel:1.0
    any[] value
    string[] channelName []
New : epics:nt/NTMultiChannel:1.0
    any[] value
    string[] channelName ["abcdefg", "hijklmn"]
$ pvget GMDTest:NTMultiChannel
GMDTest:NTMultiChannel epics:nt/NTMultiChannel:1.0
    any[] value
$ pvget GMDTest:NTScalar
GMDTest:NTScalar 0
$ pvput GMDTest:NTMultiChannel channelName="[GMDTest:NTScalar]"
    any[] value
Unknown token ':' in ":NTScalar]"Error: Unknown token
    any[] value
$ pvput GMDTest:NTMultiChannel '{"channelName":["GMDTest:NTScalar"]}'
JSON syntax not supported by this build.
I’ve tried many combinations of single-quotes and double-quotes in different positions of the command. I’ve also tried a scape symbol “\”, but couldn’t make it work.
Thank you,
Márcio Paduan Donadio
Control Systems Engineer - SLAC
Re: pvput to channelName of NTMultiChannel is having colon parsed Michael Davidsaver via Tech-talk
Prev: Phoebus Alarm Server Kafka consumer client John Dobbins via Tech-talk
Next: Re: pvput to channelName of NTMultiChannel is having colon parsed Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
