1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Timestamping Confusion
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 14 Dec 2020 22:43:31 +0000
Partial success so far, I was able to get the TSEL to grab the timestamp from another record that was set by TSE default 0 (sys clock I think this is?).  When I set TSE to -2 can you not write to the TIME field of a record like this
Caput mydevice:abc.TIME 2020-12-14 14:38:49.021827
I was hoping to simulate my digitizer setting the timestamp in my waveform record TIME field.
From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Monday, December 14, 2020 1:32 PM
Thank you both for the insight, it seems best for us to go a similar path of using TSEL to copy the timestamp from the digitizer to each of our waveform records and using TSE set to -2 to stop the IOC from overwriting the time field (please correct me if I am wrong on this). I think I just need to understand the best way to get the first timestamp and then use TSEL to pass it along to the other records.
Ralph when you stated to have the digitizer send the timestamp with the data, would I just have my digitizer set the TIME field in the waveform record then?
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Saturday, December 12, 2020 5:25 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Timestamping Confusion
On Fri, 11 Dec 2020 at 22:33, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Thanks for the comments Michael, when you are dealing with hundreds of waveform records and the timestamps are being taken when each record is processed (I would assume these would all be off by some delay if multiple softIOCs are running) do you then just have a master time waveform to lineup all your other signals to t0?  It seems the digitizer would have a time stamp of t0 for all of its signals but the epics records would not all align at the same timestamp since each one isn't processed at t0 to be timestamped.
The EPICS Device Support needs to know the timestamp t0 (preferably sent with the data by the digitizer) and write it to each record's timestamp when it updates the record.
In that case, by configuring their TSE to -2, all waveform records can use the digitizer timestamp. That timestamp can even be forwarded (using TSEL) through post-processing chains, so that processed data may still use the timestamp that the digitizer sent with the raw data at the beginning of the chain.
Cheers,
~Ralph
RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Re: Timestamping Confusion Johnson, Andrew N. via Tech-talk
Re: Timestamping Confusion Michael Davidsaver via Tech-talk
Re: Timestamping Confusion Ralph Lange via Tech-talk
Prev: Help Erika Jones via Tech-talk
Next: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
