1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: lakeshore336 msi: Can't open file 'ioc_sns.db'
From: Juliane Reinhardt via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 14 Dec 2020 16:00:18 -0800
Dear EPICS team,
I am trying to install the lakeshore336 IOC. When compiling this module I get the following error:
make[3]: Entering directory '/home/cosmic/epics/R7.0.4/modules/support/lakeshore/lakeshore336/lakeshore_fccd/exampleApp/Db/O.linux-x86_64' /home/cosmic/epics/R7.0.4/base/bin/linux-x86_64/msi -D    -I. -I.. -I../O.Common -I../../../db -I/home/cosmic/epics/R7.0.4/modules/support/asyn-R4-36/db -I/home/cosmic/epics/R7.0.4/modules/support/lakeshore/lakeshore336/db -I/home/cosmic/epics/R7.0.4/modules/support/iocStats-3-1-16/db -I/home/cosmic/epics/R7.0.4/modules/support/autosave-R5-10/db -I/home/cosmic/epics/R7.0.4/base/db -o ../O.Common/example.db -S../example.substitutions  > example.db.d
input: '}
' at
Inflating database from ../example.substitutions
/home/cosmic/epics/R7.0.4/base/bin/linux-x86_64/msi    -I. -I.. -I../O.Common -I../../../db -I/home/cosmic/epics/R7.0.4/modules/support/asyn-R4-36/db -I/home/cosmic/epics/R7.0.4/modules/support/lakeshore/lakeshore336/db -I/home/cosmic/epics/R7.0.4/modules/support/iocStats-3-1-16/db -I/home/cosmic/epics/R7.0.4/modules/support/autosave-R5-10/db -I/home/cosmic/epics/R7.0.4/base/db -o example.db -S../example.substitutions
input: '}
' at
make[3]: *** [/home/cosmic/epics/R7.0.4/base/configure/RULES.Db:477: ../O.Common/example.db] Error 1 make[3]: Leaving directory '/home/cosmic/epics/R7.0.4/modules/support/lakeshore/lakeshore336/lakeshore_fccd/exampleApp/Db/O.linux-x86_64' make[2]: *** [/home/cosmic/epics/R7.0.4/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[2]: Leaving directory '/home/cosmic/epics/R7.0.4/modules/support/lakeshore/lakeshore336/lakeshore_fccd/exampleApp/Db' make[1]: *** [/home/cosmic/epics/R7.0.4/base/configure/RULES_DIRS:85: Db.install] Error 2 make[1]: Leaving directory '/home/cosmic/epics/R7.0.4/modules/support/lakeshore/lakeshore336/lakeshore_fccd/exampleApp' make: *** [/home/cosmic/epics/R7.0.4/base/configure/RULES_DIRS:85: exampleApp.install] Error 2
All required support modules listed in the configure/RELEASE file are successfully compiled. msi module is compiled. Could not find any help related to "ioc_sns.db".
Best,
Juliane
Juliane Reinhardt, PhD
Project Scientist | ALS Computing Group
Blg. 15-337E | phone: 510-486-4313
[email protected]
Lawrence Berkeley National Lab
Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Prev: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Next: Re: Timestamping Confusion Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Help Johnson, Andrew N. via Tech-talk
Next: Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
