Subject: Re: Splitting a string in a protocol file
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: "Runchey, John" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 17 Dec 2020 19:55:00 +0000
Hi Andy,
On Dec 17, 2020, at 1:47 PM, Wang, Andrew via Tech-talk <[email protected]> wrote:
I’m relatively new to EPICS and I have been tasked with writing drivers for a Keysight oscilloscope.
Welcome to the collaboration! I can’t answer your specific question about Streams, but one of my colleagues here at Argonne is also working on a Keysight scope driver, and you two might want to compare notes or even collaborate on a single solution if that makes sense. John might even be able to answer your Streams question, although he also has only started with EPICS fairly recently.
John, please see whether you guys can help each other out at all...
- Andrew
:CHANnel<N>:SCALe
This command requires a channel number and a value. So if I wanted to set the vertical scale of Channel 2 to 50 V, I would do
:CHANnel2:SCALe 50
I would like to work on both my protocol file and database file, but I am not sure how to go about it. This is what I currently have.
record(aao, "set_vert_scale")
              field(DESC, "Set vertical scale for a channel")
              field(DTYP, "stream")
              field(FTVL, "STRING")
              field(OUT, "@keysightOsc.proto setVertScale $(PORT)")
setVertScale
              separator = “,”
              out "%s:SCALe ";
My goal is for the user to enter a command such as caput set_vert_scale CHAN1,5 so that the string can be split in a manner such that CHAN1 and 5 can be concatenated to the beginning and end of :SCALe.
Any thoughts on how to do so?
Andy
Complexity comes for free, simplicity you have to work for.
Splitting a string in a protocol file Wang, Andrew via Tech-talk
Prev: Splitting a string in a protocol file Wang, Andrew via Tech-talk
Next: Re: Splitting a string in a protocol file Michael Davidsaver via Tech-talk
