Subject: Re: puzzle running softIocPVA
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Rolf Keitel <[email protected]>
Date: Sun, 20 Dec 2020 10:16:32 -0800
On 12/19/20 5:52 PM, Rolf Keitel via Tech-talk wrote:
> I am trying to run a simple softIocPVA.
> I created a boot directory for the ioc and copied softIocPVA and softIocPVA.dbd  from the EPICS build tree to the boot directory.
I didn't expect that anyone would do this :)
I suppose it is ironic that my attempt to enable relocation of softIoc* should
backfire in this situation.  I assumed that the entire build tree would be
copied so that the softIoc executable(s) and corresponding .dbd files would
maintain their relative locations.  The ../../dbd/softIoc*.dbd you see is
relative to the directory containing the executable, not $PWD.
> I am using the following st.cmd script:
> The IOC starts as I expect in EPICS 7.0.3, but not in 7.0.4.1
> In 7.0.4.1 the dbd file is not found and I get the following error message (I massaged the output and inserted <boot directory> for my lengthy IOC boot directory path):
> Rolf Keitel, Ph.D
> TRIUMF, 4004 Wesbrook Mall
> Vancouver, BC, V6T 2A3
> Tel.: 604 222 7453
> e-mail: [email protected] <mailto:[email protected]>
> -- The old generation has to die off so that a new set of idiots can make the same mistakes all over again --
Re: puzzle running softIocPVA Johnson, Andrew N. via Tech-talk
puzzle running softIocPVA Rolf Keitel via Tech-talk
Prev: puzzle running softIocPVA Rolf Keitel via Tech-talk
Next: Re: puzzle running softIocPVA Johnson, Andrew N. via Tech-talk
