IIRC the original softIoc had an option to specify the DBD file path on the command line (-D perhaps), and I don’t think Michael removed that so you might be able to get it to work by adding that option, possibly to your st.cmd’s #! line.
- Andrew
Complicity is easy, Simplexity takes real work
> On Dec 20, 2020, at 12:16 PM, Michael Davidsaver via Tech-talk <[email protected]> wrote:
> On 12/19/20 5:52 PM, Rolf Keitel via Tech-talk wrote:
>> I am trying to run a simple softIocPVA.
>> I created a boot directory for the ioc and copied softIocPVA and softIocPVA.dbd from the EPICS build tree to the boot directory.
> I didn't expect that anyone would do this :)
> I suppose it is ironic that my attempt to enable relocation of softIoc* should
> backfire in this situation. I assumed that the entire build tree would be
> copied so that the softIoc executable(s) and corresponding .dbd files would
> maintain their relative locations. The ../../dbd/softIoc*.dbd you see is
> relative to the directory containing the executable, not $PWD.
>> I am using the following st.cmd script:
>> The IOC starts as I expect in EPICS 7.0.3, but not in 7.0.4.1
>> In 7.0.4.1 the dbd file is not found and I get the following error message (I massaged the output and inserted <boot directory> for my lengthy IOC boot directory path):
>> Rolf Keitel, Ph.D
>> TRIUMF, 4004 Wesbrook Mall
>> Vancouver, BC, V6T 2A3
>> Tel.: 604 222 7453
>> e-mail: [email protected] <mailto:[email protected]>
>> -- The old generation has to die off so that a new set of idiots can make the same mistakes all over again --
- Re: puzzle running softIocPVA Michael Davidsaver via Tech-talk
- puzzle running softIocPVA Rolf Keitel via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
