Subject: Re: Question about the font name for EDM
To: tech-talkepics <[email protected]>, lzfneu <[email protected]>
Date: Wed, 30 Dec 2020 09:39:59 +0800
Hi, neu
    A softlinked file can be built after 75dpi installed with yum.
    # ln -s /usr/share/X11/fonts/75dpi /etc/X11/fontpath.d/75dpi
    100dpi can be built in the same way.
    I have used this way on any centos7 version.
Mi Qingru
SARI CAS
Date: 2020-12-30 02:00
Subject: Tech-talk Digest, Vol 14, Issue 665
Send Tech-talk mailing list submissions to
Message: 1
Date: Tue, 29 Dec 2020 04:07:56 +0000
To: EPICS tech-talk <[email protected]>
Subject: Question about the font name for EDM
Message-ID:
Content-Type: text/plain; charset="gb2312"
Deal all,
Recently I have update centos 7 to the version: CentOS Linux release 7.8.2003 (Core)
However, edm cannot be run correctly as before, the new problem is as follows when typing edm command in the terminal:
No such font available: [-*-century schoolbook l-medium-r-normal--0-80-75-75-p-0-*-*]
Last line processed: 12
Font init failed - abort
I have already set the following command in bashrc:
xset fp+ /usr/share/X11/fonts/75dpi
and the problem still occurs.
Maybe I should install new font and I have no idea what the font name is I should type using yum install command.
Thank you in advance.
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20201229/ca27a861/attachment.html>
Subject: Digest Footer
Tech-talk mailing list [email protected]
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 14, Issue 665
回复: Question about the font name for EDM lzf neu via Tech-talk
Prev: RE: Reading multiple parameters from an incoming message. Mark Rivers via Tech-talk
Next: 回复: Question about the font name for EDM lzf neu via Tech-talk
Prev: Question about the font name for EDM lzf neu via Tech-talk
