1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: 回复: Question about the font name for EDM
To: 米清茹 <[email protected]>, tech-talkepics <[email protected]>
Date: Wed, 30 Dec 2020 02:58:20 +0000
Thanks for your reply.
I have tried but the same problem still exists.
Maybe my updated CentOS 7 system is lack of "century schoolbook font", the corresponding font package I searched in the web is "texlive-palatino-svn28614.0-45.el7.noarch.rpm".
However, when I yum install it, the terminal gives the following information:
Package 2:texlive-palatino-svn28614.0-45.el7.noarch already installed and latest version.
I have no idea what the problem  is.
Thank you in advance.
发件人: 米清茹 <[email protected]>
发送时间: 2020年12月30日 1:39
收件人: tech-talkepics <[email protected]>; lzfneu <[email protected]>
主题: Re: Question about the font name for EDM
Hi, neu
    A softlinked file can be built after 75dpi installed with yum.
    # ln -s /usr/share/X11/fonts/75dpi /etc/X11/fontpath.d/75dpi
    100dpi can be built in the same way.
    I have used this way on any centos7 version.
Mi Qingru
SARI CAS
Date: 2020-12-30 02:00
Subject: Tech-talk Digest, Vol 14, Issue 665
Send Tech-talk mailing list submissions to
Message: 1
Date: Tue, 29 Dec 2020 04:07:56 +0000
To: EPICS tech-talk <[email protected]>
Subject: Question about the font name for EDM
Message-ID:
Content-Type: text/plain; charset="gb2312"
Deal all,
Recently I have update centos 7 to the version: CentOS Linux release 7.8.2003 (Core)
However, edm cannot be run correctly as before, the new problem is as follows when typing edm command in the terminal:
No such font available: [-*-century schoolbook l-medium-r-normal--0-80-75-75-p-0-*-*]
Last line processed: 12
Font init failed - abort
I have already set the following command in bashrc:
xset fp+ /usr/share/X11/fonts/75dpi
and the problem still occurs.
Maybe I should install new font and I have no idea what the font name is I should type using yum install command.
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20201229/ca27a861/attachment.html>
Subject: Digest Footer
Tech-talk mailing list [email protected]
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 14, Issue 665
Re: Question about the font name for EDM Johnson, Andrew N. via Tech-talk
Re: Question about the font name for EDM 米清茹 via Tech-talk
Prev: Re: Question about the font name for EDM 米清茹 via Tech-talk
Next: 回复: Reading multiple parameters from an incoming message. Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Question about the font name for EDM Johnson, Andrew N. via Tech-talk
