1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Question about the font name for EDM
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: lzf neu <[email protected]>
Cc: 米清茹 <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 31 Dec 2020 18:42:00 +0000
On Dec 29, 2020, at 8:58 PM, lzf neu via Tech-talk <[email protected]> wrote:
I have tried but the same problem still exists.
Maybe my updated CentOS 7 system is lack of "century schoolbook font", the corresponding font package I searched in the web is "texlive-palatino-svn28614.0-45.el7.noarch.rpm".
However, when I yum install it, the terminal gives the following information:
Package 2:texlive-palatino-svn28614.0-45.el7.noarch already installed and latest version.
I have no idea what the problem  is.
On my RHEL-7 system the Century Schoolbook fonts are called “new century schoolbook” (your error message doesn’t have “new” in the name) and are installed in these standard X11 packages:
xorg-x11-fonts-75dpi-7.5-9.el7.noarch
xorg-x11-fonts-100dpi-7.5-9.el7.noarch
etc. You almost certainly have those installed, so my question is why edm is looking for “century schoolbook” instead of “new century schoolbook”. Our (now very old) installation of edm has this line in the edmMain/fonts.list file
new century schoolbook=-*-century schoolbook l-(medium,bold)-(r,i)-normal--0-(80,90,100,110,120,140,180,240,320,480,720)-75-75-p-0-*-*
but these lines in the setup/fonts.list file:
-adobe-new century schoolbook-bold-i-normal--8-80-75-75-p-56-iso8859-1
-adobe-new century schoolbook-bold-i-normal--10-100-75-75-p-66-iso8859-1
-adobe-new century schoolbook-bold-i-normal--12-120-75-75-p-76-iso8859-1
-adobe-new century schoolbook-bold-i-normal--14-140-75-75-p-88-iso8859-1
-adobe-new century schoolbook-bold-i-normal--18-180-75-75-p-111-iso8859-1
-adobe-new century schoolbook-bold-i-normal--24-240-75-75-p-148-iso8859-1
-adobe-new century schoolbook-bold-r-normal--10-100-75-75-p-66-iso8859-1
-adobe-new century schoolbook-bold-r-normal--12-120-75-75-p-77-iso8859-1
-adobe-new century schoolbook-bold-r-normal--14-140-75-75-p-87-iso8859-1
-adobe-new century schoolbook-bold-r-normal--18-180-75-75-p-113-iso8859-1
-adobe-new century schoolbook-bold-r-normal--24-240-75-75-p-149-iso8859-1
-adobe-new century schoolbook-bold-r-normal--8-80-75-75-p-56-iso8859-1
-adobe-new century schoolbook-medium-i-normal--10-100-75-75-p-60-iso8859-1
-adobe-new century schoolbook-medium-i-normal--12-120-75-75-p-70-iso8859-1
-adobe-new century schoolbook-medium-i-normal--14-140-75-75-p-81-iso8859-1
-adobe-new century schoolbook-medium-i-normal--18-180-75-75-p-104-iso8859-1
-adobe-new century schoolbook-medium-i-normal--24-240-75-75-p-136-iso8859-1
-adobe-new century schoolbook-medium-i-normal--8-80-75-75-p-50-iso8859-1
-adobe-new century schoolbook-medium-r-normal--10-100-75-75-p-60-iso8859-1
-adobe-new century schoolbook-medium-r-normal--12-120-75-75-p-70-iso8859-1
-adobe-new century schoolbook-medium-r-normal--14-140-75-75-p-82-iso8859-1
-adobe-new century schoolbook-medium-r-normal--18-180-75-75-p-103-iso8859-1
-adobe-new century schoolbook-medium-r-normal--24-240-75-75-p-137-iso8859-1
-adobe-new century schoolbook-medium-r-normal--8-80-75-75-p-50-iso8859-1
Did you perhaps miss a step when installing edm?
- Andrew
发件人: 米清茹 <[email protected]>
发送时间: 2020年12月30日 1:39
收件人: tech-talkepics <[email protected]>; lzfneu <[email protected]>
主题: Re: Question about the font name for EDM
Hi, neu
    A softlinked file can be built after 75dpi installed with yum.
    # ln -s /usr/share/X11/fonts/75dpi /etc/X11/fontpath.d/75dpi
    100dpi can be built in the same way.
    I have used this way on any centos7 version.
Mi Qingru
SARI CAS
Date: 2020-12-30 02:00
Subject: Tech-talk Digest, Vol 14, Issue 665
Send Tech-talk mailing list submissions to
Message: 1
Date: Tue, 29 Dec 2020 04:07:56 +0000
To: EPICS tech-talk <[email protected]>
Subject: Question about the font name for EDM
Message-ID:
Content-Type: text/plain; charset="gb2312"
Deal all,
Recently I have update centos 7 to the version: CentOS Linux release 7.8.2003 (Core)
However, edm cannot be run correctly as before, the new problem is as follows when typing edm command in the terminal:
No such font available: [-*-century schoolbook l-medium-r-normal--0-80-75-75-p-0-*-*]
Last line processed: 12
Font init failed - abort
I have already set the following command in bashrc:
xset fp+ /usr/share/X11/fonts/75dpi
and the problem still occurs.
Maybe I should install new font and I have no idea what the font name is I should type using yum install command.
Thank you in advance.
Subject: Digest Footer
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 14, Issue 665
Complexity comes for free, simplicity you have to work for.
Re: Question about the font name for EDM 米清茹 via Tech-talk
回复: Question about the font name for EDM lzf neu via Tech-talk
Prev: 回复: Reading multiple parameters from an incoming message. Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: 回复: Question about the font name for EDM lzf neu via Tech-talk
Next: Re: 回复: Reading multiple parameters from an incoming message. Hu, Yong via Tech-talk
