On 1/19/21 8:30 AM, Hu, Yong via Tech-talk wrote:
> Does anyone have a ready-to-use db file (picoharp.db) for PicoHarp 300?
> I managed to build the pico library from source codes: https://github.com/Araneidae/picoharp <https://github.com/Araneidae/picoharp> , but failed to generate the db file because the building process seems heavily dependent on Diamond Light Source internal environment.
> Another question: has anyone managed to use a USB-to-Ethernet converter to control PicoHarp 300 through the EPICS driver?
I recently had cause to run an old/cheap oscilloscope with software
usb over ethernet using usbip on Linux[1]. This worked well as an
ad hoc setup which I only needed for an afternoon.
However, even in that time it was obvious that re-connection,
or recovery from USB device reset, are not handled well.
I had to manually unbind/re-bind, and restart my application, each
time to get things working again. I wouldn't want to try to keep
a setup like this running for an extended period.
[1] as in 'apt-get install usbip'
- PicoHarp 300 Hu, Yong via Tech-talk
RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Manoussakis, Adamandios via Tech-talk
RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Pearson, Matthew R. via Tech-talk
<2021>
2025
2026
Re: PicoHarp 300 Abbott, Michael (DLSLtd, RAL, LSCI) via Tech-talk
<2021>
2025
2026
