1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PicoHarp 300
From: "Abbott, Michael \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
Date: Thu, 21 Jan 2021 08:49:59 +0000
Hi Yong,
Tom has pointed your query out to me (afraid I've not been monitoring this mailing list for some time, I hope you get this).
You should be able to build the database file using epicsdbbuilder which you can find at https://github.com/Araneidae/epicsdbbuilder .  I'm afraid it looks like the link in the readme for picoharp goes to the wrong place, just pick up the current version from github.  This tool is not Diamond specific (anymore...)!
Let me know if you have any problems building this and I'll be happy to help.
Michael Abbott
From: Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>
Sent: 21 January 2021 08:43
To: Abbott, Michael (DLSLtd,RAL,LSCI) <[email protected]>
Subject: Fw: PicoHarp 300
I guess this might be a question for you?
Tom
From: Tech-talk <[email protected]> on behalf of Hu, Yong via Tech-talk <[email protected]>
Sent: 19 January 2021 16:30
To: [email protected] <[email protected]>
Subject: PicoHarp 300
Does anyone have a ready-to-use db file (picoharp.db) for PicoHarp 300?
I managed to build the pico library from source codes: https://github.com/Araneidae/picoharp , but failed to generate the db file because the building process seems heavily dependent on Diamond Light Source internal environment.
Another question: has anyone managed to use a USB-to-Ethernet converter to control PicoHarp 300 through the EPICS driver?
Yong
The following is my configuration and tests:
configure/RELEASE:
EPICSDBBUILDER = /home/yhu/epicsdbbuilder
configure/CONFIG_SITE:
PYTHON = /usr/bin/python
make[2]: Leaving directory `/direct/iocs_diagnostics/picoharp/picoharpApp/src'
make -C ./Db install
make[2]: Entering directory `/direct/iocs_diagnostics/picoharp/picoharpApp/Db'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/direct/iocs_diagnostics/picoharp/picoharpApp/Db/O.linux-x86'
/usr/bin/python ../picoharp.py ../O.Common/picoharp.db
Traceback (most recent call last):
  File "../picoharp.py", line 1, in <module>
    from support import *
  File "/direct/iocs_diagnostics/picoharp/picoharpApp/Db/support.py", line 12, in <module>
    from epicsdbbuilder import *
ImportError: No module named epicsdbbuilder
make[3]: *** [../O.Common/picoharp.db] Error 1
$ ipython
In [1]: from epicsdbbuilder import  *
In [2]: pwd
Out[2]: u'/home/yhu/epicsdbbuilder'
PicoHarp 300 Hu, Yong via Tech-talk
Prev: RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Pearson, Matthew R. via Tech-talk
Next: Strange CAS error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: PicoHarp 300 Michael Davidsaver via Tech-talk
