Hello, I have to interface HP3458A DMM using Agilent 82357A over LinuxGPIB driver on EPICS 7. I am able to communicate with the device using the stream module. I now see a module supporting HP3458A is available. Does this module use the latest ASYN interface libraries? -> http://www.aps.anl.gov/epics/download/modules/hp3458a_cvs.tar.gz The last modification to this library seems to be in 2004. subsequently I understand there were major changes in how the ASYN interface uses the GPIB bus Reason I am asking this question is because this HP3458A module has lots of functions and commands incorporated. Which I will have to redo if I use the bare stream interface. Please suggest me ways to incorporate support for HP3458A in the latest version Thank you in advance. Regards, Kuldeep
ANJ, 22 Jan 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
