1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Strange CAS error
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 22 Jan 2021 13:41:05 +0000
I think this happened when he installed a new EPICS IOC at an APS beamline.  Perhaps it is a port scanner on the CA ports, rather than a real CA client?
Sent: Thursday, January 21, 2021 11:16 PM
To: Mark Rivers
Cc: [email protected]
Hi Mark,
This is from the release notes for 3.16.1, from about 5 years ago:
Channel Access "modernization"
Drop support for CA clients advertising protocol versions less than 4.
This effects clients from Base older than 3.12.0-beta1. Newer clients will continue to be able to connect to older servers. Older clients will be ignored by newer servers.
This allows removal of UDP echo and similar protocol features which are not compatible with secure protocol design practice.
Another possibility is that some other non-EPICS device may be opening a TCP socket and sending data to the IOC server that it thinks might be the start of a legitimate connection.
If your colleague has a client built against a CA client library that predates 3.12.0-beta1 which can’t be recompiled, it should be possible to put a CA gateway between it and the newer IOC to do the appropriate protocol translation.
- Andrew
Complicity is easy, Simplexity takes real work
On Jan 21, 2021, at 6:37 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
A colleague is running an IOC on which he is seeing these messages:
CAS: request from 146.137.70.29:47932<http://146.137.70.29:47932/> => CAS: Client version too old
CAS: Request from 146.137.70.29:47932<http://146.137.70.29:47932/> => cmmd=18245 cid=0x54502f31 type=12064 count=18516 postsize=21536
CAS: Request from 146.137.70.29:47932<http://146.137.70.29:47932/> =>   available=0x2e310d0a         N=0 paddr=0000000000000000
I have never seen those before.  What cause cause a "Client version too old" error?
Re: Strange CAS error Johnson, Andrew N. via Tech-talk
Strange CAS error Mark Rivers via Tech-talk
Prev: Interfacing HP3458A DMM using LinuxGPIB. Kuldeep Joshi via Tech-talk
Next: Re: Interfacing HP3458A DMM using LinuxGPIB. Wang, SuYin Grass via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Strange CAS error Johnson, Andrew N. via Tech-talk
Next: Re: Strange CAS error Johnson, Andrew N. via Tech-talk
