Subject: Re: enabling pvaccess
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Randall Cayford <[email protected]>
Cc: "Engbretson, Mark S. via Tech-talk" <[email protected]>
Date: Fri, 22 Jan 2021 22:02:47 +0000
Hi Randall,
On Jan 22, 2021, at 3:56 PM, Randall Cayford via Tech-talk <[email protected]> wrote:
I’ve got several IOCs built with EPICS7 and synApps 6.1.  They work with channel access but not with pvaccess (meaning caget works fine, pvget times out.
Is there something I need to do either in the IOC or in building EPICS/SynApps to enable PVaccess support in my IOCs?
Yes, this is from the example template Makefile:
# Link QSRV (pvAccess Server) if available
ifdef EPICS_QSRV_MAJOR_VERSION
    example_LIBS += qsrv
    example_LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
    example_DBD += PVAServerRegister.dbd
    example_DBD += qsrv.dbd
endif
You don’t need the ifdef conditional though unless you might want to build the IOC against an EPICS build that doesn’t have the qsrv stuff built.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
enabling pvaccess Randall Cayford via Tech-talk
Prev: enabling pvaccess Randall Cayford via Tech-talk
Next: MCA toolbox Debasis Sinhamahapatra via Tech-talk
