Subject: Python cothread errors
From: "Ha, Kiman via Tech-talk" <[email protected]>
Cc: "Kongtawong, Sukho" <[email protected]>
Date: Tue, 26 Jan 2021 05:20:26 +0000
Hi All,
We were trying to collect waveform data from the single point softIOC, a total of 180 * 100,000 points.
Before, it works fine, but recently, we found unexpected cothread error messages.
Can someone advise how to fix these errors?
$python save_sdi_no_trig.py test2
start: number of data: 100000
  burst length: 11 s
  read data...
Traceback (most recent call last):
  File "save_sdi_no_trig.py", line 83, in <module>
    faX  = caget(fa_x_pv, count=record_len)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 739, in caget
    return caget_array(pvs, **kargs)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 636, in caget_array
    for pv in pvs])
  File "/usr/lib/python2.7/dist-packages/cothread/cothread.py", line 1047, in WaitForAll
    result.append(event.Wait(timeout))
  File "/usr/lib/python2.7/dist-packages/cothread/cothread.py", line 661, in __run
    self.__function(*self.__args, **self.__kargs))
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 122, in throw_wrapper
    return function(pv, *args, **kargs)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 624, in caget_one
    return ca_timeout(done, timeout, pv)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 149, in ca_timeout
    raise ca_nothing(name, cadef.ECA_TIMEOUT)
cothread.catools.ca_nothing: SR:SDI2FA:C23{BPM3}ADMA-X: User specified timeout on IO operation expired
# Global SDI data collection script
import os
import sys
import h5py
import matplotlib.pyplot as plt
import time
import datetime
import cothread
#from scipy import *
#from numpy import *
from cothread.catools import *
#from cothread import Timedout
# input parameters
comment = sys.argv[1]
save_dir = 'HLA_result'
burst_len_sp = 11 # time to store data in CC buffer [s]
record_len = 100000 # number of data to read from PVs
update_n_check = 5
update_t_wait = 1
# start
t0 = time.time()
print('start: number of data: ' + str(record_len))
init_burst_len = caget('SR:SDI2FA{}BurstLen-SP')
if (init_burst_len != burst_len_sp):
    caput('SR:SDI2FA{}BurstLen-SP', burst_len_sp)
    print('  set new burst length to ' + str(burst_len_sp) + ' s')
else:
    print('  burst length: ' + str(init_burst_len) + ' s')
# directories and filename
if not(os.path.exists(save_dir)):
    os.mkdir(save_dir)
suffix = datetime.datetime.now().strftime("%Y%m%d_%H%M_%S")
filename = 'SR_CCSDI_FA_' + suffix + '_'+ comment + '.h5'
# generate PVs
# normal BPM
prefix_data = []
prefix_bad = []
p_index = ['1','2','3','4','5','6']
Cell_index = ['30','01','02','03','04','05','06','07','08','09','10','11','12','13','14','15','16','17','18','19','20','21','22','23','24','25','26','27','28','29']
for i in Cell_index:
    for j in p_index:
        prefix_data.append('SR:SDI2FA:C'+i+'{BPM'+j+'}')
        prefix_bad.append('SR:C'+i+'-APHLA{BPM:'+j+'}')
# ID BPM (only upto 8 BPMs max)
p_index = ['7','8']
Cell_index = ['02','03','04','05','07','08','10','11','12','16','17','18','19','21','23','28']
    for j in p_index:
fa_x_pv = []
fa_y_pv = []
bad_x_pv = []
bad_y_pv = []
for i in range(len(prefix_data)):
    fa_x_pv.append(prefix_data[i] + 'ADMA-X')
    fa_y_pv.append(prefix_data[i] + 'ADMA-Y')
    bad_x_pv.append(prefix_bad[i] + 'PSD:BadX-Cmd')
    bad_y_pv.append(prefix_bad[i] + 'PSD:BadY-Cmd')
# collect data
I = caget('SR:C03-BI{DCCT:1}I:Total-I') # beam current
fin_cnt = caget('SR:SDI2FA{}TrigCnt-I') # initial trigger count
# read data from PVs
print('  read data...')
t = time.time()
faY  = caget(fa_y_pv, count=record_len)
badX = caget(bad_x_pv)
badY = caget(bad_y_pv)
print('    (lasted ' + str(round(time.time() - t, 2)) + ' s)')
# save .h5 file
print('  save hdf file...')
t = time.time()
fid = h5py.File(os.path.join(save_dir, filename), 'w')
fid['I'] = I
fid['prefix'] = prefix_data
fid['faX'] = faX
fid['faY'] = faY
fid['badX'] = badX
fid['badY'] = badY
fid['trig_cnt'] = fin_cnt
fid.close()
print('complete...(' + str(round(time.time() - t0, 2)) + ' s)')
Re: Python cothread errors Hu, Yong via Tech-talk
Prev: Re: Altering timestamp of softIOC PV Johnson, Andrew N. via Tech-talk
Next: RE: EPICS Archiver routing issue Abdalla Ahmad via Tech-talk
Prev: RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
Next: Re: Python cothread errors Hu, Yong via Tech-talk
