Subject: Re: Channel connection performance
To: "Veseli, Sinisa" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jan 2021 23:10:58 +0000
On an ordinary Linux server, I did a few tests using cothread, which is a python binding of EPICS V3 Channel Access. And I got similar results as Sinisa got:
# Firstly, get a list of PVs (i.e. from a file). Connecting to 1269 PVs (which are from lots of different IOCs) takes about 0.3-seconds
>>> len(pvs)
1269
>>> pvs[:10]
['ACC-TS{EVG-AcTrig}Bypass-Sel', 'ACC-TS{EVG-AcTrig}Divider-SP', 'ACC-TS{EVG-AcTrig}Phase-SP', 'ACC-TS{EVG-AcTrig}SyncSrc-Sel', 'ACC-TS{EVG-Dbus:0}Map-Sel', 'ACC-TS{EVG-Dbus:0}MapConv-Sel_', 'ACC-TS{EVG-Dbus:0}Omsl-FOut', 'ACC-TS{EVG-Dbus:0}Src-Sel', 'ACC-TS{EVG-Dbus:1}Map-Sel', 'ACC-TS{EVG-Dbus:1}MapConv-Sel_']
>>> from cothread.catools import connect
>>> import time
>>> t0=time.time(); results = connect(pvs, cainfo=True, throw=False); t1=time.time(); print(t1-t0)
0.299956083298
# another test on 38380 PVs: connection takes less than 7-seconds
>>> len(pvs)
38380
6.67425608635
http://controls.diamond.ac.uk/downloads/python/cothread/
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: "Veseli, Sinisa" <[email protected]>
Date: Monday, January 25, 2021 at 3:48 PM
If you are already using pvaClientCPP, you could also take a look at the MultiChannel class (examples can be found here: https://github.com/epics-base/exampleCPP/tree/master/exampleClient/src)
Here is how long it takes on my machine to connect and retrieve values for 1000 CA channels using pvapy (both client and IOC are running on the same machine):
>>> import time
>>> from pvaccess import *
>>> cList = ['X%s' % i for i in range (1,1001)]
>>> c = MultiChannel(cList, CA)
>>> t0 = time.time(); pv=c.get(); t1=time.time() ; print(t1-t0)
0.21088194847106934
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
Sent: Monday, January 25, 2021 2:19 PM
To: Axel Terfloth <[email protected]>
Cc: [email protected] <[email protected]>
On 1/25/21 11:00 AM, Axel Terfloth via Tech-talk wrote:
> Hello,
> i’m new to EPICS and take a closer look at it for evaluation purpose. To obtain a better understanding I started to dig deeper by implementing some tests which are based on the C++ examples. From a functional point of view everything I tried works nicely so far. Also the performance is generally very good in most of my test scenarios. Nevertheless one issue i came across is the time required for connecting to a channel  via PVA. In this scenario I set up 4000 process variables and implement one client which implements high frequency put and get access to a quarter (1000) of these proces variables. On my machine (which runs all processes for now) if takes about 250ms for a single channel connection. Once all channels are connected is really fast. Nevertheless connecting 1000 pvs takes more than 6 minutes. I currently connect channel by channel using the PvaClient API in my tests. Is there a more efficient way to connect to a large set of channels?  I would appreciate any hint.
Can you be more specific about what you application is doing?  A common source
of slowdown with CA or PVA clients is for user code the is to perform network
operations in sequence.  This can be done in parallel, which can give a nice speedup.
You might want to investigate my new (hopefully replacement) PVA library
which makes it easy to run many operations in parallel.
https://mdavidsaver.github.io/pvxs/
eg. the equivalent of 'pvget'
https://github.com/mdavidsaver/pvxs/blob/d0e82744d30256e36585b51af2704cc01a938e18/tools/get.cpp#L109-L132
If this isn't an option, then is the 'pvac' wrapper API which provides a
similar abstraction, though with more verbose syntax.
http://epics-base.github.io/pvAccessCPP/
eg. parallel get operations
http://epics-base.github.io/pvAccessCPP/examples_getme.html
Re: Channel connection performance Matt Newville via Tech-talk
Channel connection performance Axel Terfloth via Tech-talk
Re: Channel connection performance Michael Davidsaver via Tech-talk
Re: Channel connection performance Veseli, Sinisa via Tech-talk
Prev: Re: Difference between caput/caget and PVwrite Michael Davidsaver via Tech-talk
Next: Re: Channel connection performance Matt Newville via Tech-talk
Prev: Re: Channel connection performance Veseli, Sinisa via Tech-talk
