Hi
Which areadetector driver should be used to interface AVT(Allied Vision)-Marlin F033B
Firewire camera on Windows OS? I tried a few of them and below are my observations.
- ADProsilica - Apparently, when I use "prosilicaConfig("$(PORT)", 5000698, 50, 0)" in st.cmd; the IOC crash. Somewhere I read ADprosilica has been tested only with
gigE cameras.
- ADVimba - The IOC runs with "ADVimbaConfig("$(PORT)", "$(CAMERA_ID)", 0, 0, 0)" . But the template files it uses "dbLoadRecords("$(GENICAM_DB_FILE)", "P=$(PREFIX),R=cam1:,PORT=$(PORT)")" can only be generated using arv-tools on Linux.
(Downloading the XML files -
https://areadetector.github.io/master/ADGenICam/ADGenICam.html). Does someone has the XML configuration files for the said model?
- ADFireWireWin - Not tried yet. Does this works with the above model?
Many Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
- RE: Areadetector driver for AVT-Marlin Firewire Camera on Windows Mark Rivers via Tech-talk
Re: autosave -- NOWRITE pvs request Mooney, Tim M. via Tech-talk
<2021>
2025
2026
RE: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue Manoussakis, Adamandios via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
