1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Extern "C" when defining aSub records
Date: Tue, 2 Feb 2021 13:04:45 +0000
Hello -
I am trying to understand how to register a cpp function for an EPICS aSub record (or something similar). In particular, I am trying to understand where and how to use the extern “C” directive.
From what I understand, the extern “C” directive is there to tell the c++ compiler to use C-style linking and name mangling. This seems reasonable for any function that is going to be exposed as a function that could be used outside of my specific library, e.g. by an aSub record.
The function that is actually calling the aSub function is do_sub from aSubRecord.c. For reference:
static long do_sub(aSubRecord *prec)
    GENFUNCPTR pfunc = prec->sadr;
    long status;
    if (prec->snam[0] == 0)
        return 0;
    if (pfunc == NULL) {
        recGblSetSevr(prec, BAD_SUB_ALARM, INVALID_ALARM);
        return S_db_BadSub;
    status = pfunc(prec);
    if (status < 0)
        recGblSetSevr(prec, SOFT_ALARM, prec->brsv);
    else
        prec->udf = FALSE;
    return status;
And the function is called in the line
Given that this is from a .c file and not a .cpp file, does pfunc need to be defined with extern “C” linkage? The closest analog that I can find is from asyn, specifically asynPortDriver.cpp, which defines a number of functions such as
extern "C" {static asynStatus disconnect(void *drvPvt, asynUser *pasynUser)
And these functions are later added into interfaces that, as I understand, are called from other parts of the code, hence their C-style linkages.
Unfortunately, the example from the documentation seems to be implicitly in C, so that doesn’t help.
In summary, my question is roughly as follows:
1. For a function defined in a .cpp file which is to be used as either the INAM or SNAM parameter in an aSub record, does that function need to be declared extern “C”?
2. What about the epicsExportFunction() line? What is the relationship between these two, and do either/both/none of them need to be extern “C”d?
Thanks for your help,
Cheers,
Simon Rose
Software Engineer
European Spallation Source
Re: Extern "C" when defining aSub records Michael Davidsaver via Tech-talk
Prev: device support for Edwards active gauge controller Heinz Junkes via Tech-talk
Next: Re: Extern "C" when defining aSub records Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: device support for Edwards active gauge controller Maren Purves via Tech-talk
