1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: [EXTERNAL] Re: Question about compress records
From: "Guyotte, Greg via Tech-talk" <[email protected]>
To: "Pearson, Matthew R." <[email protected]>, Ralph Lange <[email protected]>
Date: Mon, 8 Feb 2021 23:42:18 +0000
I have tested this solution and it works beautifully.  Thanks Matt!
Sent: Monday, February 8, 2021 1:45 PM
To: Guyotte, Greg <[email protected]>; Ralph Lange <[email protected]>
Cc: [email protected]
Hi Greg,
This might be a work around, until the feature is added to the compress record. You can copy the NUSE field and write it to the N field as the circular buffer fills up:
record(ai, "$(P)$(R)Test") {
  field(VAL, "0.0")
  field(FLNK, "$(P)$(R)Buffer")
record(compress, "$(P)$(R)Buffer") {
  field(INP, "$(P)$(R)Test")
  field(ALG, "Circular Buffer")
  field(NSAM, "10")
  field(FLNK, "$(P)$(R)AverageCalc")
record(longout, "$(P)$(R)AverageCalc") {
  field(OMSL, "closed_loop")
  field(DOL, "$(P)$(R)Buffer.NUSE")
  field(OUT, "$(P)$(R)Average.N")
  field(FLNK, "$(P)$(R)Average")
record(compress, "$(P)$(R)Average") {
  field(INP, "$(P)$(R)Buffer")
  field(ALG, "N to 1 Average")
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Guyotte, Greg via Tech-talk
Sent: Monday, February 8, 2021 1:37 PM
To: Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
Subject: Re: [EXTERNAL] Re: Question about compress records
That sounds correct to me Ralph.  I’m at least satisfied to know that the current operation is as expected.  I will try the solution suggested by Tim Mooney as well – thanks Tim.
On 2/8/21, 11:50 AM, "Tech-talk" <[email protected]> wrote:
Hi Greg,
This behavior is (mostly) documented in the compress record reference manual entry.
Is it correct to write what you're missing as:
The compress record in its "N to 1 Xxx" modes, when reading an INP array that has less than NSAM * N elements (or while still filling its internal circular buffer), should use all existing elements of the INP array (or the internal buffer) and calculate as much of the resulting VAL array as possible, before firing VAL monitors and forward links.
Such a change should probably have a configuration switch, defaulting to the current behavior.
Sounds like a nice codeathon project!
Cheers,
~Ralph
Question about compress records Guyotte, Greg via Tech-talk
Re: Question about compress records Ralph Lange via Tech-talk
Re: [EXTERNAL] Re: Question about compress records Guyotte, Greg via Tech-talk
RE: [EXTERNAL] Re: Question about compress records Pearson, Matthew R. via Tech-talk
Prev: Re: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
Next: caproto ioc alarm value leakage Troup, Euan (CASS, Marsfield) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Re: Question about compress records Guyotte, Greg via Tech-talk
Next: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
