Subject: ADPilaus + NDFileHDF5
From: John Dobbins via Tech-talk <[email protected]>
Date: Mon, 8 Feb 2021 16:54:46 +0000
All,
I am trying the Pilatus with the NDFileHDF5 plug-in.  From an acquisition I end up with both TIFF (x NumImages) files and one hdf5 file and am wondering about the proper way to end up with just the hdf5.
I see in the documentation for the NDPluginFile
The base class will delete the “original” file that the driver created for that array if the following are all true:
The DeleteDriverFile record is “Yes”.
The file plugin has successfully written a new file.
The array contains an attribute called “DriverFileName” that contains the full file name of the original file. The driver attributes XML file should contain a line like the following:
<Attribute name="DriverFileName" type="PARAM" source="FULL_FILE_NAME" datatype="STRING" description="Driver file name"/>
In the NDFileHDF5 plug-in I have "Delete Driver File" = Yes
And the plug-in successfully writes the .h5 file
Regarding the third point (Attribute DriverFileName):
In the ADPilatus plug-in, should I set "Auto Increment" to No?  Which will give me a fixed "FULL_FILE_NAME".  Of course, then this file keeps getting over-written and deleting it is less relevant.
What is the best way to handle this?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
RE: ADPilaus + NDFileHDF5 Mark Rivers via Tech-talk
Prev: Re: Question about compress records Ralph Lange via Tech-talk
Next: Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
Prev: RE: [EXTERNAL] Re: Question about compress records Guyotte, Greg via Tech-talk
Next: RE: ADPilaus + NDFileHDF5 Mark Rivers via Tech-talk
