Subject: Re: Firmware upgrade for MRF event generators and receivers
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Mon, 8 Feb 2021 09:32:11 -0800
On 2/8/21 6:37 AM, Abdalla Ahmad via Tech-talk wrote:
> Hello community
> This question is not EPICS specific, but I could use some help. We tried downgrading the firmware for spare EVG and EVR boards which have the MRM firmware 005 I think to firmware E403 and D507 respectively. I followed the procedure in the manuals but when I issue the command "u" to start the update process, the telnet session exits with message "Self-programming triggered". I came back after a while and every time I telnet to the board, it seems the device entered a mode where no command is available (only q and x commands), sometimes when the device reboots, I try to dump the memory I get "Addr 0x8000002e: error -1".
> I tried re-uploading the firmware, power-cycle, and factory settings but nothing works. Any advice how to fix the firmware update process?
Back when I was at BNL I was able to successfully update firmware on several
VME boards (I assume that's what you have).  I was always nervous though.
I can only recommend contacting MRF.  If you are lucky, and have access to
a JTAG programmer, you might be able to directly re-flash the firmware yourself.
RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Prev: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
Next: RE: ADPilaus + NDFileHDF5 Mark Rivers via Tech-talk
Prev: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Next: RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
