Hello Michael
Thanks for the feedback. Will try to contact MRF.
Side question, the firmware on MRF website is it for the processor or the FPGA or both? Should I update the processor only or both?
Best Regards,
Abdalla.
-----Original Message-----
Sent: Monday, February 08, 2021 7:32 PM
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Subject: Re: Firmware upgrade for MRF event generators and receivers
On 2/8/21 6:37 AM, Abdalla Ahmad via Tech-talk wrote:
> Hello community
> This question is not EPICS specific, but I could use some help. We tried downgrading the firmware for spare EVG and EVR boards which have the MRM firmware 005 I think to firmware E403 and D507 respectively. I followed the procedure in the manuals but when I issue the command "u" to start the update process, the telnet session exits with message "Self-programming triggered". I came back after a while and every time I telnet to the board, it seems the device entered a mode where no command is available (only q and x commands), sometimes when the device reboots, I try to dump the memory I get "Addr 0x8000002e: error -1".
> I tried re-uploading the firmware, power-cycle, and factory settings but nothing works. Any advice how to fix the firmware update process?
Back when I was at BNL I was able to successfully update firmware on several VME boards (I assume that's what you have). I was always nervous though.
I can only recommend contacting MRF. If you are lucky, and have access to a JTAG programmer, you might be able to directly re-flash the firmware yourself.
- Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
- Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
- Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
caproto ioc alarm value leakage Troup, Euan (CASS, Marsfield) via Tech-talk
答复: Question about databrowser of CSS lzf neu via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
