1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: ADPilaus + NDFileHDF5
To: 'John Dobbins' <[email protected]>
Date: Mon, 8 Feb 2021 18:13:46 +0000
Hi John,
Ø  In the ADPilatus plug-in, should I set "Auto Increment" to No?  Which will give me a fixed "FULL_FILE_NAME".  Of course, then this file keeps getting over-written and deleting it is less relevant.
There is no need to set AutoIncrement to No.  In you detector attribute XML file if you add this line:
<Attribute name="DriverFileName" type="PARAM" source="FULL_FILE_NAME" datatype="STRING" description="Driver file name"/>
then it should set that attribute to the name of the TIFF file corresponding to that NDArray, and then the HDF5 file plugin will delete the correct file, even if it has an incrementing file number in it.  Did you try that and see some issue?
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Monday, February 8, 2021 10:55 AM
To: [email protected]
Subject: ADPilaus + NDFileHDF5
All,
I am trying the Pilatus with the NDFileHDF5 plug-in.  From an acquisition I end up with both TIFF (x NumImages) files and one hdf5 file and am wondering about the proper way to end up with just the hdf5.
I see in the documentation for the NDPluginFile
The base class will delete the “original” file that the driver created for that array if the following are all true:
The DeleteDriverFile record is “Yes”.
The file plugin has successfully written a new file.
The array contains an attribute called “DriverFileName” that contains the full file name of the original file. The driver attributes XML file should contain a line like the following:
In the NDFileHDF5 plug-in I have "Delete Driver File" = Yes
And the plug-in successfully writes the .h5 file
Regarding the third point (Attribute DriverFileName):
What is the best way to handle this?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
Prev: Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
Next: RE: Question about databrowser of CSS Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
Next: Re: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
