Hi Markus,
From the looks of it, I'd say that the .war files were not copied over correctly and tomcat is having difficulties unzipping them on startup. These are just .zip files; so you can potentially use a unzip -t to make sure that the 4 .war files made it ok. You
can also unzip them manually before startup if you like using something like so
pushd ${DEPLOY_DIR}/mgmt/webapps && rm -rf mgmt*; cp ${WARSRC_DIR}/mgmt.war .; mkdir mgmt; cd mgmt; jar xf ../mgmt.war; popd;
pushd ${DEPLOY_DIR}/engine/webapps && rm -rf engine*; cp ${WARSRC_DIR}/engine.war .; mkdir engine; cd engine; jar xf ../engine.war; popd;
pushd ${DEPLOY_DIR}/etl/webapps && rm -rf etl*; cp ${WARSRC_DIR}/etl.war .; mkdir etl; cd etl; jar xf ../etl.war; popd;
pushd ${DEPLOY_DIR}/retrieval/webapps && rm -rf retrieval*; cp ${WARSRC_DIR}/retrieval.war .; mkdir retrieval; cd retrieval; jar xf ../retrieval.war; popd;
Murali
RE: ASYN Module: Workaround for bug due to improper handling of signal in linux-gpib Mark Rivers via Tech-talk
RE: Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
<2021>
2025
2026
EPICS Archiver Appliance: Fatal error when deploying the WARs (probably Java) Markus Huber via Tech-talk
Issue with record processing and being able to process records after a certain amount of delay Wang, Andrew via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
