Subject: RE: Estimate Data Rate and BW requirements
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
Date: Wed, 10 Feb 2021 17:36:17 +0000
It seems like for large number of arrays PVA in epics 7 might be the better way to go?  Is just due to the way the data is stored and transferred with PVA vs CA?
-----Original Message-----
Sent: Tuesday, February 9, 2021 1:39 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: [email protected]
Subject: Re: Estimate Data Rate and BW requirements
I think the bandwidth requirements depend almost entirely on the number of large arrays you will be sending via Channel Access.  If you use areaDetector and Channel Access to transport arrays from an IOC to a client viewer you can easily consume 100% of GigE bandwidth.  If you have a display with 1000 scaler PVs each changing at 10Hz that will only be 80kB/s (plus overhead), so it is less than 0.1% of GigE bandwidth.
From: Tech-talk <[email protected]> on behalf of Manoussakis, Adamandios via Tech-talk <[email protected]>
Sent: Tuesday, February 9, 2021 3:04 PM
To: [email protected]
Subject: Estimate Data Rate and BW requirements
Hello All,
Trying to understand a few things on data rate and bandwidth with regards to epics.  Most of epics is based off UDP/TCP, so I was thinking that your max will be related to TCP throughput calculations?
Is there a rule of thumb for epics on estimating BW requirements?
If the infrastructure is there to transmit and no BW issues what is the upper limit for data rate given a number of PVs?
Is there an upper limit depending on PVs and there sizes when doing transfers like caget?
Thanks
RE: Estimate Data Rate and BW requirements Mark Rivers via Tech-talk
Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
Re: Estimate Data Rate and BW requirements Mark Rivers via Tech-talk
Prev: Re: EPICS Archiver Appliance: Fatal error when deploying the WARs (probably Java) Shankar, Murali via Tech-talk
Next: RE: Estimate Data Rate and BW requirements Mark Rivers via Tech-talk
Prev: Re: Estimate Data Rate and BW requirements Mark Rivers via Tech-talk
