1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PVXS release 0.1.2
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 12 Feb 2021 18:25:16 -0800
On 2/12/21 12:31 PM, Michael Davidsaver wrote:
> Another patch release, primarily addressing a TCP connection "stall"
> under load.  Believed to be ABI backwards compatible with 0.1.2
> and 0.1.1.
I meant "with 0.1.1 and 0.1.0".
> download https://github.com/mdavidsaver/pvxs/releases
> documentation https://mdavidsaver.github.io/pvxs
> release notes https://mdavidsaver.github.io/pvxs/releasenotes.html
> On 1/15/21 9:00 AM, Michael Davidsaver wrote:
>> 0.1.1 is the first patch release for the PVXS module.
>> Which is a new PVAccess protocol client+server library.
>> This is a bug fix release which addresses an interoperability
>> issues with the pvAccessJava module (Thanks to karlosp) for
>> reporting.  Also a couple of more minor issues.
>> Based an analysis with abi-compliance-checker I believe that the ABI
>> of the libraries in 0.1.1 remains backward compatible with 0.1.0.  So
>> it _should_ be possible to update PVXS without rebuilding dependent
>> code.
>> ABI compatibility with C++ is still something I'm not certain about.
>> I would like to hear from anyone who tries this (successfully or
>> otherwise).
>> I've attached the report generated by abi-compliance-checker to
>> the github release.  Also a unit test coverage report from GCOVR.
>> This is a bit of an experiment.  I'm not certain if I'll continue
>> to publish these with future releases, so please let me know if
>> you find them useful.
PVXS release 0.1.1 Michael Davidsaver via Tech-talk
PVXS release 0.1.2 Michael Davidsaver via Tech-talk
Prev: PVXS release 0.1.2 Michael Davidsaver via Tech-talk
Next: EPICS Record Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: PVXS release 0.1.3 Michael Davidsaver via Tech-talk
