1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: ELMO motion control using EPICS
To: Abdalla Ahmad <[email protected]>
Date: Sun, 14 Feb 2021 12:59:48 +0000
> At the APS most of us are using Aerotech air-bearing rotation stages
I meant to say that "most of us doing tomography are using Aerotech air-bearing rotation stages"
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: Sunday, February 14, 2021 6:58 AM
To: Abdalla Ahmad
Cc: [email protected]
Hi Abdalla,
At the APS most of us are using Aerotech air-bearing rotation stages and Aerotech Ensemble or A3200 NDrive drivers. We use the Position Synchronized Output (PSO) from these drives to trigger the detector while doing continuous rotation.
You may be interested to know that we have recently developed a Python package called tomoscan that uses EPICS PVs to control all aspects of the tomography data collection.  It is easily adapted to different cameras and motion hardware.
https://github.com/tomography/tomoscan
https://tomoscan.readthedocs.io/en/latest/
Assuming that there is not an existing EPICS driver, you will need to write one.  Which specific Gold ServoDrive model do you have.  Do you have the documentation for how to control it via a socket?  This link seems to suggest that they provide a .NET library, which would be only for Windows.
https://www.elmomc.com/products/application-studio/download-resource-center/
They also mention EtherCAT.  Do they provide way of controlling it over TCP so it can easily be run from Linux?
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Sunday, February 14, 2021 4:35 AM
To: [email protected]
Subject: ELMO motion control using EPICS
Hello community
Is there an EPICS driver for the ELMO motion controller? specifically the Gold ServoDrive series? This motion controller will control the air bearing stage of the tomography beamline.
Best regards
Abdalla
ELMO motion control using EPICS Abdalla Ahmad via Tech-talk
Re: ELMO motion control using EPICS Mark Rivers via Tech-talk
Prev: Re: ELMO motion control using EPICS Mark Rivers via Tech-talk
Next: Re: EPID Record Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
