Am 16.02.21 um 14:22 schrieb Mark Rivers:
>> How is that possible? If the record was able to process its input links
>> (which it apparently did since A..D have the expected values), then
>> shouldn't it also process the CALC expression and set VAL accordingly?
> Could this be a race condition?
It very much looks like one, doesn't it?
> What would happen if there were
> multiple CA callbacks while the record was processing? Is it
> possible for one of the inputs to change state without processing the
> record again to compute the correct VAL?
This is what I suspected at first, which is why I explicitly triggered
processing by writing to PROC. This did not have the expected effect (of
re-computing and thus fixing VAL).
The next time this happens I will hopefully be able to get more
information (like doing a full dbpr); any idea what else I could do?
Cheers
Ben
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Ben Franksen via Tech-talk <[email protected]>
> Sent: Tuesday, February 16, 2021 4:56 AM
> To: EPICS tech-talk
> Subject: Yet another calc record / CPP link problem
> I have problems with a slightly complicated database that sometimes
> "hangs" in an unexpected state because some status bits aren't
> propagated as they should be. Investigating the state of the IOC I
> tracked the problem down to the following record:
> record(calcout,"BPMMUXCB:stTLIO") {
> field(CALC,"A&B&C&D=A|B|C|D?A:VAL")
> field(INPA,"BPMMUX1S16G:stT CPP")
> field(INPB,"BPMMUX1S16G:stL CPP")
> field(INPC,"BPMMUX2S16G:stI CPP")
> field(INPD,"BPMMUX2S16G:stO CPP")
> The input records are of type mbbi. The CALC expression is such that we
> check if all inputs are equal; if yes, set VAL to one of them, else
> don't change VAL.
> The problematic state is this: all inputs are zero, yet VAL=1. I checked
> that both the input fields (A..D) are zero as well as the PVs that
> supply the input values.
> Furthermore: processing the record (caput BPMMUXCB:stTLIO.PROC 1) did
> /not/ have any effect (VAL remained at 1). However, writing a different
> but equivalent expression into CALC field did resolve it: VAL then
> became 0 as expected.
> This looks similar to https://bugs.launchpad.net/epics-base/+bug/1841634
> but note that the calcout here has no ODLY set, so it should (I think)
> process synchronously.
> I case you wonder: Yes, a simple calc instead of a calcout would have
> been sufficient here; that it's a calcout is a left-over from a previous
> version. I cannot ATM verify that the calc record has the same behavior.
> This problem is very hard to reproduce. The only way I have been able to
> reproduce it is to let the Python script that drives the thing in order
> to make certain measurements run for a long time and wait until it hangs
> (waiting for readbacks to coincide with setpoints after switching the
> multiplexor to another channel).
> Cheers
> Ben
> I would rather have questions that cannot be answered, than answers that
> cannot be questioned. -- Richard Feynman
signature.asc
Description: OpenPGP digital signature
- Yet another calc record / CPP link problem Ben Franksen via Tech-talk
- Re: Yet another calc record / CPP link problem Mark Rivers via Tech-talk
RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Re: EPICS latest stable version Timo Korhonen via Tech-talk
<2021>
2025
2026
Re: Yet another calc record / CPP link problem Michael Davidsaver via Tech-talk
<2021>
2025
2026
