Subject: Re: EPICS latest stable version
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Kevin Peterson <[email protected]>, Delahaye Olivier <[email protected]>
Cc: Pillon Frank <[email protected]>, Zouaoui Djaid <[email protected]>, Sebille Florian <[email protected]>, Patard Charles-Henri <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Feb 2021 12:46:43 -0800
On 2/16/21 12:25 PM, Kevin Peterson via Tech-talk wrote:
> Olivier,
> I've seen CA misaligned protocol errors on IOCs at the APS in the past.  I believe they were caused by network security scans run by the IT group.  There was a strong correlation between the error messages and shutdown days, which is the only time IT scans the beamlines.
cf. another recent example https://epics.anl.gov/tech-talk/2021/msg00072.php
The exact wording the the warning depends on the Base version(s) involved.
Seeing messages like this occasionally is almost certainly a non-CA client attempting
to connect to a CA server.  Actual CA clients retry continually, so any real problem
would be much more verbose.
> IOCs usually didn't need to be restarted after the errors occurred.  I believe Windows IOCs were the exception.  I vaguely recall the scans crashing Windows IOCs.
Any misbehavior associated with malformed message warnings should be reported as a bug.
> Kevin
> On 2/16/21 5:15 AM, Delahaye Olivier via Tech-talk wrote:
>> Hi,
>> I'm working at GANIL in Caen, France.
>> We are currently using EPICS 3.14.12.4. We are facing issues about UDP CAS. (UPD: "CAS: Missaligned protocol rejected).
>> For that, we are wondering whether or not it would be interesting to switch on a more "up to date" version.
>> I would like to know what is the latest "stable" version of EPICS ?
>> I read in your download page there was "stable" versions and "current" versions. What are exactly the differences between "current" and "stable" ?
>> Are current versions stable or not ?
>> Thx for your answer,
>> Olivier Delahaye
>> /Préservons notre environnement, n’imprimez ce mail que si nécessaire./
>> /Preserve our environment, print this email only if necessary./
RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Re: EPICS latest stable version Kevin Peterson via Tech-talk
Prev: Re: EPICS latest stable version Kevin Peterson via Tech-talk
Next: Re: pmacAsynCoord in-position vs .MOVN J. Lewis Muir via Tech-talk
Next: RE: EPICS latest stable version Delahaye Olivier via Tech-talk
