I did find my answer to question
1) in the channel access pdf
EPICS_CA_ADDR_LIST="1.2.3.255 8.9.10.255"
For 3)
the reason I ask is I have an IOC running on one machine and I have been able to access it just fine from 192.168.1.X to its IP 192.168.2.X but now I am trying to run the IOC on the .1 machine and the .2 access and it cant find it for some reason. I have checked my environment variables on both machines and I was at the time using EPICS_CA_ADDR_LIST to include each others IPs.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Wednesday, February 17, 2021 9:31 PM
To: Mark Rivers <[email protected]>
Cc: [email protected]
Subject: RE: Identical Process Variable names on Multiple Servers
Thanks Mark, I will try that out. I think I tried doing it before and I wasn’t having much success with the broadcast address but I understand a bit more about EPICs not so I can hopefully debug if its something else.
This does lead me three other questions though
1) If I have multiple addresses I need to list in EPICS_CA_ADDR_LIST
Is the proper way EPICS_CA_ADDR_LIST=[192.168.1.255 192.168.2.255]?
2) I am wondering if I have multiple IOCs running on my linux machine do I need to then start to worry about starting up the CARepeater if I use the broadcast addressing?
3) If I have multiple subnets such as above 192.168.1.x and 192.168.2.x, will I run into issues if I don’t setup cagateways or am I misunderstanding there use?
Adam
Sent: Wednesday, February 17, 2021 6:17 PM
To: Manoussakis, Adamandios <[email protected]>
Subject: Re: Identical Process Variable names on Multiple Servers
It is because you have more than one network interface and you are running the IOC and client on the same machine.
You can set EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST to the broadcast address of one of the interfaces.
Sent from my iPhone
On Feb 17, 2021, at 8:00 PM, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Hey All,
Having a weird issue where I try to run a very simple IOC with a few analog out records and getting CA.Client.Exception
Warning: Identiical Process variable names on multiple servers
Context: Channel calc:a connecting to ubuntu:5064 ignored: localhost:5064
Ubuntu is my hostname on this VM and this is the first time I have encountered this when just running a single IOC.
Thanks
- Re: Identical Process Variable names on Multiple Servers Mark Rivers via Tech-talk
- Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
- RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Re: Accessing waveform record values in C Andy Foster via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
