Subject: Re: Accessing waveform record values in C
From: Andy Foster via Tech-talk <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: [email protected]
Date: Thu, 18 Feb 2021 08:22:15 +0000
Hi Andy,
Have you set the field type of field "A" in the aSub record to CHAR? FTA set to CHAR.
Cheers, Andy
On Thu, 18 Feb 2021, 05:23 Wang, Andrew via Tech-talk, <[email protected]> wrote:
All,
Basically I have a waveform record that contains ASCII values of chars shown below.
record(waveform, "waveform_record")
              field(DESC, "")
              field(SCAN, "Passive")
              field(FTVL, "CHAR")
              field(NELM, 250)
When I input caget waveform_record, I get:
waveform_record 250 72 101 108 108 111 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.
My goal is to access 72, 101, 108, 108, and 111 in a C code for an asub record.
record(aSub, "asub_record")
              field(DESC, "")
              field(SNAM, "c_code")
              field(INPA, "waveform_record")
              field(NOA, 250)
In my C code, I attempt to access the waveform record.
char *waveform_record = (char *)prec->a;
printf("%s\n", waveform_record);
The terminal only prints out 72, the first element. But when I try to do
printf("%s\n", *(waveform_record + 4));
I get a segmentation fault rather than 111. Any advice on how I could potentially access the other elements in the waveform record? Feel like I am missing something very basic here.
Andy
Re: Accessing waveform record values in C Hu, Yong via Tech-talk
Accessing waveform record values in C Wang, Andrew via Tech-talk
Prev: RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Next: Re: pmacAsynCoord in-position vs .MOVN Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Accessing waveform record values in C Wang, Andrew via Tech-talk
Next: Re: Accessing waveform record values in C Hu, Yong via Tech-talk
