1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Identical Process Variable names on Multiple Servers
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Date: Thu, 18 Feb 2021 07:13:56 -0800
On 2/18/21 7:01 AM, Ralph Lange via Tech-talk wrote:
> On Thu, 18 Feb 2021 at 13:39, Mark Rivers via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>     Was the .1 machine running more than one IOC?  If so, then this could be the problem.  Using the IP address of the .1 machine in the EPICS_CA_ADDR_LIST on .2 will only work for the first IOC started on .1.  It will not be able to find the second IOC.  This is because the second IOC needs to use a different port for Channel Access.
> Almost.
> When using an explicit IP for the name search, only the /last/ IOC started on that machine will answer.
FYI. first vs last depends on host OS, and as I recall windows and linux differ.
So I think you both are right.
> See this how-to page <https://epics-controls.org/resources-and-support/documents/howto-documents/channel-access-reach-multiple-soft-iocs-linux/> for a discussion and possible fixes. The second IOC does not need to use a different port.
As for the problem at hand.  If possible, it would help if we could see
the IP configuration of both hosts.  And also to know what, if any,
firewall rules are involved.
Things I look at:
1. host firewall configurations
2. mis-configured broadcast address
Both the .1 and .2 host must have the same broadcast address set.
Re: Identical Process Variable names on Multiple Servers Ralph Lange via Tech-talk
Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Re: Identical Process Variable names on Multiple Servers Mark Rivers via Tech-talk
RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Prev: Re: Identical Process Variable names on Multiple Servers Ralph Lange via Tech-talk
Next: Re: Identical Process Variable names on Multiple Servers Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
