I don’t think the Wireshark version will matter. Have you put a filter on what Wireshark captures, or on what is selected to display?
Sent from my iPhone
On Feb 18, 2021, at 8:26 PM, Li, Ji <
[email protected]> wrote:
Thanks Mark. I expect Wireshark to be install & play. The one I used is an old installation on an old server. Will find another one and try it out.
Best,
-Ji Li
发件人: Mark Rivers <
[email protected]>
发送时间: 2021年2月18日 20:11
收件人: Li, Ji <
[email protected]>
抄送:
[email protected] <
[email protected]>
主题: RE: How to capture messages generated by PyEpics?
Ø When I get/set from PyEpics (tried both PV module and CA module), the program was able to successfully get the up-to-date value of the PV and set new value to it,
Ø > but no messages showed up. Doesn't PyEpics communicate using CA protocol messages? Are there specific filter/configuration to be done in Wireshark to show these messages?
There is no difference in the CA network messages using caget and PyEpics. They both use the same libca.so library from EPICS base.
You must have something configured wrong in Wireshark or something.
[email protected]> On Behalf Of Li, Ji via Tech-talk
Sent: Thursday, February 18, 2021 4:52 PM
To:
[email protected]
Subject: How to capture messages generated by PyEpics?
I'm trying to capture CA messages targeting a specific PV on the IOC server with Wireshark (v1.12.1) and Michael Davidsaver's cashark plugin (ca.pv or ip.addr as the filter). Wireshark was able to capture messages generated by caget/caput commands ran from
bash. When I get/set from PyEpics (tried both PV module and CA module), the program was able to successfully get the up-to-date value of the PV and set new value to it, but no messages showed up. Doesn't PyEpics communicate using CA protocol messages? Are
there specific filter/configuration to be done in Wireshark to show these messages? Thanks.
-Ji Li
