OK, I was too hasty in my reply to Torsten!
We could create a new asynMetadata interface, similar to asynOption.
typedef struct asynMetadata {
asynStatus (*writeString)(void *drvPvt, asynUser *pasynUser,
const char *key, const char *val);
asynStatus (*readString)(void *drvPvt, asynUser *pasynUser,
const char *key, char *val, int sizeval);
asynStatus (*writeInt32)(void *drvPvt, asynUser *pasynUser,
const char *key, epicsInt32 val);
asynStatus (*readInt32)(void *drvPvt, asynUser *pasynUser,
const char **key, epicsInt32**val);
asynStatus (*writeFloat64)(void *drvPvt, asynUser *pasynUser,
const char *key, epicsFloat64 val);
asynStatus (*readFloat64)(void *drvPvt, asynUser *pasynUser,
const char *key, epicsFloat64 *val);
} asynMetadata;
There would be well-defined, but extensible, values for “key”. With
asynOption on serial devices key can be “baud”, “parity”, etc. For
asynMetadata the keys could be “egu”, “low_alarm”, “high_alarm”,
“min_value”, “max_value”, etc.
*From:*Tech-talk <[email protected]> *On Behalf Of *Ralph
Lange via Tech-talk
*Sent:* Monday, March 1, 2021 8:02 AM
*To:* EPICS Tech Talk <[email protected]>
*Subject:* Re: Accessing Record fields from asyn driver
Hi Torsten,
In the context of the OPC UA Device Support, I have had this requirement
coming up, and I think it would be worthwhile doing a design for adding
this functionality.
The next important step there would be thinking about a proper
definition and an easy, generic yet comprehensive way of configuring
this mapping.
Polling for changes or subscribing to metadata is probably too resource
expensive (at least in the OPC UA case), but reading the metadata on
(re)connection should be feasible.
If you have input to this, I'd be happy to hear about it.
Cheers,
~Ralph
