Folks,
for some IO we have all logic in a PLC-ish system.
If I take an ai record as an example, the the PLC
does most of the work what we normally do in the record.
Especially:
The PLC "knows" values .EGU, HIGH, LOW, HIHI, LOLO
(and probably others) because all the work is done inside the PLC
program already.
We want of cause an EPICS integration for those kind of devices
(it could be as simple as a temperature sensor), it would be nice if we
can use the values from the PLC for e.g. .EGU and the other fields.
As is, without having to define the in the record database, with the
risk of getting thme out of sync.
And yes, we can query the PLC for all this kind of information.
The asyn framework is really excellent in doing all the polling,
but there is no way to "push" meta data into single record fields.
(Unless I create a lot of helper-records, like a stringin to hold
the .EGU field, and forward the value to the .EGU field of my ai
record).
Are there more people having the same issue ?
Enhancing asyn with this functionality could be one option,
as we have code here to influence the alarm state/severity.
Any thoughts about this ?
Thanks
/Torsten
- Re: Accessing Record fields from asyn driver Mark Rivers via Tech-talk
- Re: Accessing Record fields from asyn driver Ralph Lange via Tech-talk
Re: rectangular with visibility not being updated in MEDM Mark Rivers via Tech-talk
<2021>
2025
2026
Re: rectangular with visibility not being updated in MEDM Shuei YAMADA via Tech-talk
<2021>
2025
2026
