Hi Mark,
I tried following three and all of them behave the same wa on SL6:
1) vis="if not zero"
2) vis="calc" calc=(A>0)"
3) vis="if not zero" calc=(A>0)"
regards,
Shuei
2021年3月1日(月) 22:00 Mark Rivers <[email protected]>:
> Hi Shuei,
> Your rectangle is defined like this:
> rectangle {
> object {
> x=10
> y=50
> width=120
> height=30
> "basic attribute" {
> clr=53
> "dynamic attribute" {
> vis="if not zero"
> calc="(A>0)"
> chan="TEST:PV1"
> You have a "calc" expression, "(A>0)". But you have selected vis="if not zero". I think that if you use a calc expression you should select vis="calc" instead.
> I just tested and either is working OK with Centos7 on your visibility.adl screen. However, it is worth seeing if changing this fixes the problem for you on Scientific Linux 6.
> Mark
> ________________________________
> From: Shuei YAMADA <[email protected]>
> Sent: Sunday, February 28, 2021 10:53 PM
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: rectangular with visibility not being updated in MEDM
> Dear Mark,
> > Can you post a very simple medm screen that shows the problem? Then we can try to reproduce it.
> Attached adl file is a simple medm screen which I could reproduces the
> problem on Scientific Linux 6. I am trying to make a simple adl file
> to reproduce the problem on CentOS7, but unfortunately I couldn't so
> far.
> I investigated bit further and it seems that the problem emerges when
> a) "text", "text update", and "rectangular with visibility" are placed
> in a medm screen,
> b) and the visibility PV is identical to text update PV,
> c) and the visibility condition is true on medm startup.
> Also I attached 2 screen shots, how one of our medm screens looks like
> on CentOS7 (mainmag-NG.png) and how it is supposed to be
> (mainmag-OK.png). Each box in the screen several rectangles and text
> updates are superpositioned, and some of them are drawn as white box
> or not drawn at all. There are about 500 rectangles and 400 PVs are
> involved.
> best regards,
> Shuei
> Shuei Yamada,
> High Energy Accelerator Research Organization (KEK)
> mailto:[email protected]
Shuei Yamada,
- rectangular with visibility not being updated in MEDM Shuei YAMADA via Tech-talk
- Re: rectangular with visibility not being updated in MEDM Mark Rivers via Tech-talk
- Re: rectangular with visibility not being updated in MEDM Shuei YAMADA via Tech-talk
Job Opportunity - Control Systems Group Leader Forestiero, Suzanne via Tech-talk
EPICS 7.0.5 Released Johnson, Andrew N. via Tech-talk
<2021>
2025
2026
Accessing Record fields from asyn driver Torsten Bögershausen via Tech-talk
<2021>
2025
2026
