Hi All.
It seems my original answer did never make it to tech-talk. It can still be found below but here are some more data I gathered: Even with the suggested work-arounds I could not get labca-3.7.2 and epics-7.0.4.1 or 7.05 to work with matlab 2020b. It would either hang or crash when quitting matlab. I cut a new [labca 3.8.0 release](https://github.com/till-s/epics-labca/releases/tag/labca_3_8_0) which addresses this problem but you still need one (no need for both) of the following two work-arounds: a) use a build of epics base with posix priority scheduling disabled. In configure/CONFIG_SITE set USE_POSIX_THREAD_PRIORITY_SCHEDULING=NO then 'make clean' and 'make'. Obviously, make sure no real-time systems are using this new build. b) use LD_PRELOAD to load and initialize libCom before starting matlab LD_PRELOAD=<path_to_base>/lib/<arch>/libCom.so matlab <options> If someone has good connections to MathWorks (or a MW engineer is reading this) they could use the attached simple (and standalone) 'mex' file to reproduce the problem (w/o any epics). Cheers - Till On 3/1/21 5:56 PM, Miroslaw Dach wrote:
/* Demonstrate a problem with pthread_join() from initialization * code under matlab2020b * * For a more realistic example you can compile this file into * a library (mimicks an external library): * * g++ -DBUILD_AS_LIBRARY -shared -fPIC mexJoin.cc -o libXXX.so * * and a separate mex-file: * * mex -cxx -DBUILD_AS_MEXFILE mexJoin.cc -L. -lXXX * * Alternatively, the code can be compiled into a single mexfile: * * mex -cxx mexJoin.cc */ /* Use stdio for printing messages to ensure matlab is not interfering. * Must use matlab in CLI mode, however, in order to see the messages: * * matlab -nodisplay -nosplash -nojvm * * (or watch the terminal window from where the matlab GUI was started) */ /* Author: Till Straumann <[email protected]>, 2021 */ #include <string.h> #include <errno.h> #include <pthread.h> #include <stdlib.h> #include <stdio.h> #if ! defined(BUILD_AS_LIBRARY) && ! defined(BUILD_AS_MEXFILE) #define BUILD_AS_LIBRARY #define BUILD_AS_MEXFILE #endif extern "C" { int join_a_thread(int skip); }; #ifdef BUILD_AS_LIBRARY static void * some_thread(void *arg) { fprintf(stderr, "Thread terminated\n"); return 0; } extern "C" { int join_a_thread(int skip) { pthread_t id; switch ( skip ) { case 1: fprintf(stderr, "Skipping thread creation and joining during initialization phase\n\n"); return -1; case 2: fprintf(stderr, "Skipping thread creation and joining during finalization phase\n\n"); return -1; case -1: fprintf(stderr, "Attempting thread creation and joining during initialization phase\n"); break; case -2: fprintf(stderr, "Attempting thread creation and joining during finalization phase\n"); break; default: fprintf(stderr, "Attempting thread creation and joining from mexFunction\n"); break; } if ( pthread_create( &id, 0, some_thread, 0 ) ) { fprintf(stderr, "Unable to create thread\n\n"); return -1; } fprintf(stderr, "Created a thread\n"); // 2020b under RHEL7 (compiled with g++ 9.3.0) // deadlocks in 'pthread_join' -- somewhere in // MW's glibc-2.17_shim.so. The same happens // when code which attempts 'pthread_join' from // a global initializer is loaded with dlopen(). // // NOTE: 'join_a_thread()' works fine when executed // from the mex-function itself; the deadlock // occurs only when this is attempted during // library initialization! fprintf(stderr, "Attempting to join the thread\n"); if ( pthread_join( id, 0 ) ) { fprintf(stderr, "Unable to join thread\n\n"); return -1; } fprintf(stderr, "Successfully joined!\n\n"); return 0; } } // Set the environment variable 'SKIP_JOIN_DURING_INIT' (prior to starting // matlab) to verify that joining works when executed from the mexFunction // itself. class Initializer { public: Initializer() { join_a_thread( ( (!! getenv("SKIP_JOIN_DURING_INIT")) ? 1 : -1) ); } ~Initializer() { join_a_thread( ( (!! getenv("SKIP_JOIN_DURING_EXIT")) ? 2 : -2) ); } }; static Initializer v; #endif #ifdef BUILD_AS_MEXFILE #include <mex.hpp> #include <mexAdapter.hpp> using namespace matlab::data; using matlab::mex::ArgumentList; class MexFunction : public matlab::mex::Function { public: void operator()(matlab::mex::ArgumentList o, matlab::mex::ArgumentList i) { //mexLock(); -- could prevent unloading join_a_thread(0); } }; #endif
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
