Subject: Storing an array element as a scalar in a record
From: "Wang, Andrew via Tech-talk" <[email protected]>
Date: Sat, 6 Mar 2021 01:39:50 +0000
All,
So I have a waveform record that allows four numbers to be stored. I tried to use the subArray record to get the ith element from the array. I set the MALM, NELM and INDX fields to be 1, 1, and 2 respectively. However, when I process the subArray record, I get the first element of the array, rather than the third element.
If this is not a viable way to go about it, are there other potential ways to store a scalar from an array in a record aside from using an asub record?
Any insight into this would be greatly appreciated.
Andy
Re: Storing an array element as a scalar in a record Johnson, Andrew N. via Tech-talk
Prev: Re: New to EPICS - v4 questions Marty Kraimer via Tech-talk
Next: Re: Storing an array element as a scalar in a record Johnson, Andrew N. via Tech-talk
Prev: EPICS 7.0.5 C++ Normative Type library version Ralph Lange via Tech-talk
