All,
It is not possible to honor PP or NPP options; the put operation completes immediately but whether the destination record will process depends on the process passive attribute of the destination field.
Could I get a clarification that? The reason why is because earlier in the Passive Process section, it says that
It determines if the linked record should be processed before getting a value from an input link or after writing a value to an output link.
From what is described in the second section, it appears that we can specify PP or NPP in the OUT field of a record. However, in the first portion, it appears to say otherwise.
Thank you!
- Re: Question about OUTLINK from the manual Johnson, Andrew N. via Tech-talk
Re: Storing an array element as a scalar in a record Wang, Andrew via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
