Hi, Today i wrote a simple serial communication IOC for Arduino and all
the steps went successfully but showed a package parse error and
couldn't read the protocol and .db files for the Arduino. I followed the steps given on: The following was shown in the terminal: #!../../bin/linux-x86_64/helloWorldIOC < envPaths epicsEnvSet("IOC","iochelloWorldIOC") epicsEnvSet("TOP","/home/udit/EPICS/IOCs/helloWorldIOC") epicsEnvSet("ASYN","/home/udit/EPICS/support/asyn") epicsEnvSet("CALC","/home/udit/EPICS/support/calc-R3-7-3") epicsEnvSet("STREAM","/home/udit/EPICS/support/StreamDevice") epicsEnvSet("EPICS_BASE","/home/udit/EPICS/epics-base") epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db") cd "/home/udit/EPICS/IOCs/helloWorldIOC" ## Register all support components dbLoadDatabase "dbd/helloWorldIOC.dbd" helloWorldIOC_registerRecordDeviceDriver pdbbase drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyUSB0") asynSetOption("SERIALPORT",-1,"baud","115200") asynSetOption("SERIALPORT",-1,"bits","8") asynSetOption("SERIALPORT",-1,"parity","none") asynSetOption("SERIALPORT",-1,"stop","1") asynSetOption("SERIALPORT",-1,"clocal","Y") asynSetOption("SERIALPORT",-1,"crtscts","N") ## Load record instances #dbLoadRecords("db/xxx.db","user=udit") cd "/home/udit/EPICS/IOCs/helloWorldIOC" dbLoadRecords("db/arduino.db","PORT=SERIALPORT") cd "/home/udit/EPICS/IOCs/helloWorldIOC/iocBoot/iochelloWorldIOC" iocInit Starting iocInit ############################################################################ ## EPICS R7.0.4.2-DEV ## Rev. R7.0.4.1-186-g5593103c11157aada4e4-dirty ############################################################################ 2021/03/08 10:31:16.749971 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db' 2021/03/08 10:31:16.750018 _main_ while reading protocol 'set_digital' for 'led:set' 2021/03/08 10:31:16.750025 _main_ led:set: Protocol parse error 2021/03/08 10:31:16.750032 _main_ led:set: Record initialization failed Error (514,11) PV: led:set ao: init_record 2021/03/08 10:31:16.750066 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db' 2021/03/08 10:31:16.750078 _main_ while reading protocol 'get_analog' for 'photo:get' 2021/03/08 10:31:16.750091 _main_ photo:get: Protocol parse error 2021/03/08 10:31:16.750107 _main_ photo:get: Record initialization failed iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=udit" epics> Let me know how to remove this error. Best Regards Udit
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
